Dension Gateway 100/300 Group Buy!
Hi all, I've just returned from my stag weekend. Bit fuzzy around the edges but I'll reply to PMs etc now.
wega3k - I still haven't tested the Spotify thing as I don't even know what it is!
eeperman - Yes, it does charge the iPhone 3G :)
Any update on despatch? Just wondering if i might get a chance to hack my car apart this weekend?! :)
cheers shark_90 ,got mine today and its now fitted and working. just a shame i managed to knacker my aeriel connection, doh :(
Many are out for delivery today and the remainder should be out to be delivered tomorrow :)
Am I too late to jump on this?
Only picked the car up yesterday!
Give me a call (telephone number on the website) and I'll see what I can do!
Wooo, got mine today!
Just got to get the f*cking trim off the dash and I can get around to installing it...
Thanks Ben
Thanks Ben
Got mine this morning - thanks Ben. Likewise with regard to the trim/radio etc. Success will be after much swearing probably....
Anyone else having problems getting up and running? I've got it to play from a USB flash drive, but no matter what I do cannot get any new menus on Maxidot to navigate..
no problems with mine what so ever
Ok daft question. How do I get the radio out ?
if its a stream, you remove the console trim by prising it off gently. Then in each corner of the radio there is a small block which pops out to reveal a t20 torx screw. Remove all 4 screws and it should slide out and all you need to do then is detach the wiring harness
Have PM'd a couple of people who are having problems although I'm not really around this week due to getting married yesterday! I'll try to help where I can but bear in mind I might not be around :thumbup:
Going to try and find the time to install this weekend, but studying the Quadlock loom I notice that the male connector (the one that mimics the back of the unit) is missing the AUX IN pins, so I will therefore loose the use of the AUX IN connector in the Jumbo box :(
I understood that I was gaining a second AUX IN option, not loosing the one I already had :confused:
As an aside, it looks like I'll still have use of the CD Changer (not that I ever use it) as the Dension i/f unit only connects to the AUX IN, CAN BUS and Power :)
  • 3 years later...
Any news on the Spotify part? Does it work with Dension 100
