steering wheel
ive search on here and got no luck with the topic
i need to remove the steering wheel as ive got a replacement one but the haynes manual is really c*ap to be honest
has anyone removed it and if so how could they share there expertise
cheers if anyone can help
nik
You need to use a long flat headed screwdriver in the 2 holes that are exposed by turning the wheel 90 degrees from centre each way to release the airbag. You do this one at a time above the steering column. Once released return the wheel to the centre and disconnect the battery before removing the airbag. The wheel is then removed with a M12 spline drive.
thank for that the manual doesnt mention anything about a flat blade should of tryed that really and again thanks
nik
In case it's not clear you do this from the rear of the steering wheel.
yer i know thanks 4 the info
nik
