Headlamp lens - replaceable or not?
Are the headlamp plastic lenses removable from the headlamp unit?
Or is the headlamp a complete unit?
I want to remove the headlamp plastic lens, and replace it with a new one (is it possible to buy the plastic lens anyway?)
AFAIK the lens is bonded on, and is removable without a lot of messing about
and i'm sure the lens isn't available from a dealers, so full headlamp unit is required
Theres some complete headlight units (standard) on ebay going cheap.
Otherwise, I believe they are bonded on, and have to be heated in the oven / by hairdryer to prise them apart.....
Hi
Yeh they do come apart I did mine to paint the trims black. If you can get hold of one cheap it's not worth messing about. It takes about 20 min to get it apart carefully.
There is a "how to" in the fabia guides section.
Regards Chris
thanks for all the help.
I did find a helpful thread showing how to seperate them and paint the trims - just what I was thinking of doing.
Did any of the VRs models come with darkened headlamps as standard? If so maybe it's easier just to buy those lamps off the shelf?
No, AFAIK they didn't...
Thanks for the link - are these blacked out lamps OEM?
Anyone have them on their car here - how are the beam patterns?
