VRS Exhaust
what can i use to clean the tail pipe of my fabia vrs, ive tried giving it a good scrub but it still has lots of black gunk on, how can i get this off and get it all clean and shiney? thanks Glenn
sounds harsh but mine was like this once i got my rs. i use wirewool and autosol in the are where the round ports are. worked tip top and after used some regular auto glym and it looked like new. now a quick wash and it shines again. sweet ;)
cheers, ill try that tomorrow, what technique di you use, did you put the autolsol onto te wirewool? thanks
yea mate with a little water just to stop the metal scratching and to help lift the dirt etc. try not to use it to harshly on the chrome oval part of the tailpipe though as it may damage it. bit of time and patience and it will look mint!
I beleive the gauge of wire wool is 00.
Once you've got it cleaned up you can also use dedicated alloy wheel sealants (Poorboys/ChemicalGuys spring to mind if you have some) on the tailpipe which will make future washing a doddle:thumbup:
IIRC someone on here once used lemons/juice to good effect on thier tailpipe? :confused:
As stated above Wirewool, Autosol and a Microfibre cloth will yield good results........:thumbup:
I'm sure I have heard that before as well. You should cut a fresh lemon in half and use that to rub it on. Of course there is the trick of putting Peanut Butter (I can't remember which sort) on plastic bumpers to clean them. The other thing I use on mine is to remove old polish from plastic trim or rubber window seals is a pencil rubber and it works a treat.
The alternative to a lemon is Autosol as mentioned above or Brasso.
