cleaning the standard Air filter for vrs
Hi,
I'm not sure this post has been asked before as most questions relate to performance air filter cleaning and this is not what this is about.
I wondered whether anyone reuses their standard air filters? i've got one sat which is 3 months old and not that dirt and I thought instead of buying a new one, how about just clean it up with some compressed air and a hoover
Can this be done? or does using compressed air just force the dirt further in?
But at about £6 for a new one is it worth the effort?
As mike has said for the price of them you might as well just get a new one, plus if u do try cleaning it their paper so you run the risk of damaging it (even if you don't think you have)....
For £6 for a new filter it's hardly worth it, and for piece of mind i know which i'd prefer..
Kev
I got a pipercross filter. 32quid. i personally clean every 5000miles using water and fairy liquid. much better air flow/performance than standard filter. been using for the last 2 years.
Just replace your paper filter every 10k, not every 40. Reverse-jetting (cleaning with compressed air) isn't recommended for paper filters for the reasons already given.
Panel filters have a much larger effective screen size than paper filters, and rely on oiling to 'catch' dust particles by surface tension as they pass the fibres rather than trapping them in the pores, as is the case with a paper filter. Oiling is a risky business on modern cars, as over-oiling can screw the MAF. But not oiling (FAO fabia145re-map!) is even riskier, as the dust particles pass straight through into the engine... :(
just bought an OEM filter whilst out on me travels - £13ish from the stealer.
Still better value that aftermarket plus oil, plus cleaner, plus new MAF (because I would over-oil it!) IMHO
PL
Just like Fabia 145. Now 120K and no problems.
Last time I changed mine (couple of weeks ago) I cleaned the inside of the airbox and couldn't believe how minging it was!
Might be worth doing this if you hadn't already thought of it! :)
Must be Snake Oil they put in the cleaning kits, then... :rofl:
Think I'll stick to paper all the same. :)
