Windows update problem?
I've found one of my Server 2003 machines has a little issue with updates. IE runs but when I go to windows update I get as far as picking "custom" or "express" then
[Error number: 0x80072EFD] The website has encountered a problem and cannot display the page you are trying to view.
None of the instructions I've found so far have helped.
Any ideas before I end up wiping it and rebuliding?
All of our other machines have their updates done by a WSUS server but we can't do the same for this one.
I think where you have gone wrong there is using windows update in the first place! I have always found doing updates that it has caused more problems than it has fixed!
Don't fix what isn't broken I say!
Sorry I couldn't be of any more constructive help!
Phil
I remember coming across it in a previous job, but I never actually solved it. I'm sure you've Googled all the possible solutions, which all tell you that it's a communication issue between the server and MS update. I think I ended up rebuilding the box in the end.
Phil
Phil
Yep , one of the pages I read had a direct link to a particular file on the windows update site , and if you could download that then it proved that internet connectivity was ok and the issue must be somewhere on the server.
Annoyingly that's exactly what happened - I'd have preferred it not to have worked as then it would be an issue with our firewall which I could have batted off to someone else to fix , but no such luck.
All instances I've had of this have been admin rights issues.
Interesting.
This is a server in a DMZ that isn't part of our domain.
I'll check permissions.
