1 week, 400 miles, first problem...
Evening all,
Been getting to grips with the Furby over the last week (quite a shift from 2 litre turbo RWD coupe to TD FWD hatchback!)
Washed it for the first time today and have discovered something worrying - the lacquer finish on the alloys is really poor - brake dust, and presumably water, has managed to get under the lacquer on all 4 wheels to some extent, no amount of scrubbing would shift it :eek:
And water has also got under the clear plastic cover of the skoda badges on the centre caps, which has subsequently started to lift up
Naturally I'm not happy :mad:
Anybody else had this problem? I haven't contacted the dealer yet, but they surely must replace the wheels under warranty if they're going this way after a week, right?
Evening all' date='
Anybody else had this problem? I haven't contacted the dealer yet, but they surely must replace the wheels under warranty if they're going this way after a week, right?[/quote']
Can't speak for the alloy itself, but the cover over the centre caps is just a removable protective designed to come off.
Yep, on closer inspection I feel partially stupid as that's true :rolleyes:
But with that little dumbass question out of the way, how about the lacquer???
i thought i had the same problems but it was clear sticky plastic covers over the badges,and protective wax on the wheels which just needs plenty of elbow grease
I have some diamondbrite, I was thinking about trying that if I can shift the brake dust that's already on there... but if it has got under the lacquer, then protective wax won't help :(
I also thought I had the same problem, but te muck comes off with some elbow grease. On my car, it only affected one wheel.
Cars are often supplied to the dealer with a special solvent, for removing the protective wax that cars are coated in before leaving the factory. You could pop back to the dealer, and ask them to have a look at them: they should probably shift the wax for you.
I also thought I had the same problem' date=' but te muck comes off with some elbow grease. On my car, it only affected one wheel.
Cars are often supplied to the dealer with a special solvent, for removing the protective wax that cars are coated in before leaving the factory. You could pop back to the dealer, and ask them to have a look at them: they should probably shift the wax for you.[/quote']
Hmmm, some vigorous rubbing of the spokes with a dry finger rather than a wet sponge suggests this might be the problem... but the dealer is 60 miles away and I can only get there at weekends. Bug and tar remover should shift the wax, right?
