octavia 2009 air blower sudden death
hello guys
suddenly when i tried to start the air condition tonight , everything is ok except i cant feel any air from the vents, i tried to change the speed of the air blower nothing happend, still no air
by cheking with VCDS
i got this fault code :
Address 08: Auto HVAC Labels: 3T0-907-044.clb
Control Module Part Number: 3T0 907 044 AB HW: 3T0 907 044 AB
Component and/or Version: Climatronic 122 0203
Software Coding: 0100000000
Work Shop Code: WSC 73430 790 00999
ASAM Dataset: EV_Climatronic A01001 (SK46)
1 Fault Found:
9485974 - Air Blower
B10BE 96 [009] - Component internal failure
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 6
Reset counter: 78
Mileage: 8078 km
Date: 2005.14.09
Time: 22:34:24
what is the problem
Have you tried clearing the fault with vcds? This sometimes clear the problem and fault.
quote name='Mohamed Nassar' date='25 December 2009 - 20:53' timestamp='1261774429' post='1842476']
hello guys
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 6
Reset counter: 78
Mileage: 8078 km
Date: 2005.14.09
Time: 22:34:24
what is the problem
thanks for replying me, yeah i cleared the fault , the strange thing is that i still cant get any air from the vents , while now vcds i am getting no fault code anymore !!!!!!!!!!!!!
hello guys
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 6
Reset counter: 78
Mileage: 8078 km
Date: 2005.14.09
Time: 22:34:24
what is the problem
If it was a sudden failure, check the fuses as well as clearing the codes.
D
Have you tried checking the fuses?
yeah i checked the fuses and i found something so strange , according to the manual there is 2 fuses for the air blower " #22 and #40 "
i found only #22 and it is fine while the other is not existing !!!! , but the blower was working 3 days ago
i really cant understand
thanks god it is working again :)))))))))) :thumbup: :thumbup: :D
i taped 3 times under Storage compartment on the front passenger side , then i started the fan and now it is working
many thanks god
and to all who tried to help me
Sounds like it may be a dodgy connection.
I expect God will un-fix it in a few days time B)
D
