DTC 16727 & 16395
Hello,
I have scanned with vag com after engine light came on;
16727 - Camshaft Position Sensor (G40): Signal too High
P0343 - 35-00 - -
16395 - Bank 1: Camshaft A (Intake): Retard Setpoint not Reached (Over-Advanced)
P0011 - 35-10 - - - Intermittent
I have replaced ignition coils and spark plugs because I had also misfire problems on two cylinders, the car was fine about a week and then problems started.
Now engine while hot won`t start sometimes, example 2 out of 5 times.
Engine sounds good and there is no lost of power, like everything is OK.
Could it be the problem in camshaft sensor or something else?
Octy mk1, 1.8T AUQ.
Best regads,
Igor
