help!
I own a skoda fabia VRS 55 reg, i was going along about 30 and lost power were the turbo usualy kicks in and the dreaded white smoke, i had the turbo changed with a recondisioned one, now im not getting white smoke but im not getting power and on the computer it says 17965 charge pressure control positive deviation, p1557 intermittent. any advise on were to go yet ????
taken from the Ross Tech Wiki site
17965/P1557/005463 - Charge Pressure Control: Positive Deviation
Possible Symptoms
Reduced power output
Limp mode
Possible Causes
Boost Pressure too High
Hoses/Pipes incorrect connected, disconnected, blocked or leaking
Charger Pressure Control defective
VNT (variable nozzle turbo): nozzles stuck
Solenoid Valve for Boost Pressure Control (N75) defective
Possible Solutions
Check Hoses/Pipes to/between Components
Check Solenoid Valve for Boost Pressure Control (N75)
Check / Clean / Replace Charge Pressure Control
Check / Clean mechanism for variable nozzles
Possible Symptoms
Limp mode
Possible Causes
Possible Solutions
thanx il get my machanic to try that hes stuck i dont want to take it to a expensive skoda garage yet
