cruise control
would a fabia vrs headlight cruise control stralk fit a octavia VRS MK1 ?
It would fit but not work the cruise control iirc
ok , just seen on on e-bay cheap . i know it needs to be wired up and put on the computer to do it . would it work if i did that ?
It would quite possibly fit, both the MKI Octavia and Fabia use part No. 8L0 953 513 J
(But there is also an 'S' available for the Octavia and there is also part No. 3U0 953 513 D & B to fit the Octavia)
HTH
Ask westallc, he knows everything, he's my hero.
you r a ****
:p B)
Edited by westallc
you r a ****
That's the nicest thing anyone has ever said to me.......thanks. emoticon-0110-tongueout.gif
When I grow up, I also want to be just like westallc, he is so masterful, and has a wonderful command of the english language, especially punctuation and when to use capital letters....LOL
Hi yer Clive!!!!!!
might be worth a buy then . only a £5 at moment . what will i need to get it fitted ? any wiring im going to need ? i know i need a VAG.com to fit it
I'm also searching for help on cruise control fitting - this time a 51 plate Octavia 1 VRS. I bought a retro fit (original) kit from a VW dealer - new edition stalk. This came with the extra wiring for the 1.8T 180.
My friend fitted it and enabled it on VAGCom but no joy. He says it might be because I had the car re-mapped???
Any help or ideas would be greatly appreciated.
Harveyh123
Harveyh123
on a 51 plate you may still have a throttle cable for the engine.. cruise wont work if you have a cable, if not have your mate check for brake light switch faults. also is it defo wired correctly as it can be a pain to get the wires into the correct holed in the multi block
