Favorit Speedo meter/Rev counter
My rev counter does not work,anyone know if the Favorit Rev counter gets its reading from the Speedo meter?,If not where does it connect to?
Edited by WeekendMechanic
no it gets its signat from either the ecu (if it has one) or the coil itself
Damb,I don`t have either on mine,any Idea how to hook it up to a diesel engine?
not really mate, the felicia diesels use the altenator to get a rpm sig but not sure if ti would work with yours
Gettting a tacho pulse for a diesel means either running a feed off the alternator (qv), or using a mechanical drive tacho.
That`s whats getting me I have 3 wires going into the alternator 1 is battery,other is from chase and the other is to the instrument panel,does not work, I`m flitting the whole interior along with my instrument panel to a 94 black model I have to keep my old circuit board, fuel gauge and engine temp because the 94 don`t fit ,I don`t know do, you think it will work with a new rev counter do you think maybe the old one is broken?Is that all that is required right a pulse?Anyhow it`s no use if I don`t have everything connected up with a multimeter in my hand maybe it`s the alternator....
maybe replace the rev counter with a clock instead? :rofl:
