climate control
is it possible to fit climate control to a 2002 ambient?
if so what will i need, face unit loom etc.
thanks in advance
ian
I think climate control also comes with motorised flaps and possibly sensors?
Not an easy job I think, not to say it isn't possible.
i like a challenge, i'm just trying to find some one who can deactivate my immobiliser so i can fit my remote start alarm.
i'm quite good qith stuff like that.
i used to have an e30 bmw whichi fitted cruise control, aircon, abs, towbar and rewired the whole ice system with 10 speakers and 2 amp/subs.
What will you need? I think you should look for a rear-ended GLXi, Elegance, L&K or vRS model, because the heater box is different, there's an extra sunlight sensor on the dash, the control panel, compressor and brackets, different auxilliary drive arrangement, condensor. Get the idea?
Edited by KenONeill
ok sounds a bit harder than expected, will i need to change all of the aircon conponents to do it?
or is it possible to adapt what i already have?
Ah, I'd presumed you didn't have air con. If you do, I have no idea beyond that you should have most or all of the engine bay hardware you need.
well thats a little say of sunshine. might have to put up a wanted ad for a climate controla panel.
thanks
Contact Ben at Shark Performance (a site sponsor) i'm sure its something he can help you with.
