Rear wiper washer jet problem only 2 out of 3 jets working
Hi all
my rear wiper on 2003 octy elegance has a part attached to wiper arm with 2 jets facing upwards to screen and 1 jet facing down towards the hatch(when arm in parked position)
the 2 upper jets are working fine - however the lower jet nozzle 'appears' to have swivelled in the housing so that the actual hole is not visible.
i can't get any kind of grip on it to try and swivel it back round
Anybody help?
on the part when you remove from the supply hose and the wiper arm - you can see what i assume is a part no 110.793
however i cant find this listed anywhere on the net to poss order a new one
cheers
Steve
My 53 plate Octy only has 2 jets, can't see any sign of a third.
Does your car have the early type rear wiper arm with the exposed wiper blade or the later type with a cover over the blade?
Mine has the later one.
mine has the exposed arm - really strange the jets tho - there's deffo a 'silver ball' in the bottom of the fitting which i'm assuming is a jet
cant see any other reason for it being there otherwise
