bluetooth on FL VRs
Hi new to the forum as only just ordered a vrs I went for a black cr170 dsg but wish i had chosen bluetooth and parking sensors now. I've seen the guide to fitting the bluetooth but its on a pre FL model. Will all the parts be the same for the FL vrs to do a retro install? Also is there anyone in the south that can code it for me, if so how much?
If you've only just ordered then maybe the dealer can add on what you need before they get a build date?
Factory fit is a lot better!
P.S. Welcome to Briskoda! :thumbup:
I added options no problem at all after my original order. If you want to stop spending money though don't read this forum . . .
Make absolutely sure your phone is RSAP compatible before you put the order in though. If it is then the factory kit is brilliant.
