How To: Remove / Delete SAI , N249 and N112
I have done this on mine, removed the SAI, N249 and N112 and I always get the secondary air injection ecu error.  I fitted one of the arcol resistors to my secondary pump connector and still got the CEL light come back.  I haven`t fitted resistors to anything else.  Is it all in our heads?  Fitting resistors to the N249 and N112??  Because my car went through an emissions test and passed its MOT without any resistors fitted.  So how can it be affecting fuelling?
Don`t get me wrong I would love to get the CEL light to go away on mine because it makes me paranoid.
A question for Bowders..
Is there a specific way round the arcol resistor has to be connected to the SAI connector for it to work and the other connectors??  My car did just recently fail emissions test but i'm certain its nothing to do with the removal of these components as my car passed its emissions last time with everything removed..  The new MOT'er I used recently insists it failed emissions though because the CEL light is on lol.  I scanned it today using Torque and the only error is the secondary air injection valve failure as usual.
  • Replies 67
  • Views 134.8k
  • SAI, N249 and N112 Removal Part 3 Final Part of removal of N249 and N112 Start by removing the Metal bracket holding the N249 and N112 units. To do this you will need to unclip the 3 hoses that c
  • Eccentric Toast
    Eccentric Toast
    Someone with a better understanding for all this will be along shortly to correct me but 1. Yes it is for the 1.8t Petrol 2. The main reason most people do it is to tidy up the engine bay. but it al
  • Right folks, I have painfully restored this DIY thread. Took me many hours and weekends to finally build it back up. All my photos were lost so I have had to search the WWW to get as close to same pi
What is your fault code? Is it an open circuit fault or performance/flow fault?
Hi Buddy.
Typically the car should not fail emissions through removal of those parts even without resistors fitted. I would be more inclined to check your hoses are all tight and not split etc
Are you running a sports cat as these can be very tight on emissions and mine recently failed too. Also sometimes over fueling on a performance maps can cause high emissions. My old postal map failed emissions
I have since fitted a high power fuel pump which also cold effect my emissions
I know a lot of folks not running with resisters at all and pass emissions, Resistors  is really to stop cell lights and fool the ECU in thinking the removed components are still attached which don't always work as you found.
A number of things can effect the emissions hope you get it sorted..
Stil have yet to do this, but..... FYI for anyone looking, the p/n for the bracket that holds the temp sensor (in the way of the SAI hose removal/blanking) is 06A 121 132 AP. It includes an o-ring for the block but not one for the temp sensor. I will add the number for the temp sender o-ring when I get it.. not sure if it will be required but better safe than sorry!
  • 8 months later...
Hi guys.
Does anyone know if a 3watt 330 ohm wire bound resistor would do the trick? Looking at maplin website
  • 10 months later...
sorry to bring this back up after so long "yes nearly 3 years"
Bowders,
Sorry to bother you but I just want to bring up a question about the SAI removal, and the N249 removal.
you quotes this in your Blog "The original DV hose can be removed and replaced with a longer hose that goes from DV to inlet manifold nipple that used to have a hose from the T piece from the N249 valve."
Can you please let me know which and where this goes as I'm getting a bit stuck,
your help would be much appreciated
Kind Regards
Hi mate if you removed all the items including hard lines and hoses you should have a spare nipple under right side of inlet manifold to take new DV hose to inlet nipple.
cheers Buddy
  • 8 months later...
I can't really express how much restoring all the pictures in this thread would be helpful, in fact if you have them all and want to build up a new thread or something (one which should be stickied) i can permanently host the images someplace where they'll never ever be deleted
  • 8 months later...
Hi guys,
Thanks for the write up Bowders, can't wait to do this to mine.
Could a leak in this SAI or related areas be cause to my loss of power? I don't seem to get the same amount of power, used to touch the peddle and can feel the torque building up quite quickly, now it's just mostly flat and almost have to wind it up to change gear. Occasionally some of the power comes back, but not like before. My fuel economy is rubbish too, I guess the engine is running real rich as the fuel isn't getting the necessary amount of air to burn it. Grrrrrr
Edited by mynameismud76
Good timing this guide popping back up again - planning to ditch mine soon, lol. Does the combi valve have to come off, or can it just be unplugged and left in place?
Hi all,
Almost read to do the deletes and have found this Youtube clip making this little project even clearer:
Hope others might find it useful.
Does anyone know what's are the two lines he pulled from behind the coolant reservoir?
Cheers.
On 12/08/2017 at 20:53, mynameismud76 said:
Hi all,
Cheers.
The two lines are the breather system for the fuel tank such that as the tank empties and you refuel, the vapour vents through the carbon canister and not direct to the atmosphere.  Part of the emissions control system.   For my mk1 Octavia vrs,  I have deleted the SAI and simplified the vacuum system together with a catch can but left the carbon canister in place.
  • 1 year later...
Sorry to bring thos back up.
Just to confirm, am I correct there is only 3 resistors needed. one for SAI and two for the N249 and 112.
so 3 on total???
Edited by drew_smith
  • 7 years later...
I'm probably going to be the last person in history to attempt this! Unfortunately I'll have no car for about a week, and that's if things go to plan. Garry C said 'we did this on a sunday morning' - this will take me days!! Even if I were to fit the resistors first, I'm pretty sure I couldn't drive with pipes missing and open holes in the manifold, etc.
So what's the suggested order of procedure? Remove SAI, N249, N112, then the Evap system.... then fit a catch can?
I've been trying to figure out the cost- and sourcing the lengths of hose. I've got issues with lack of boost and oil leaks, and the VCDS report seems to make this project even more worthwhile (secondary air injection valve blocked,evap system malfunction due to leaky gaskets, turbo leaking a bit on input and output). Still don't know if my turbo is shot or if my power loss is due to leaks of air and oil across the system(s).Report also mentioned wastegate and turbo bypass valves being worn /slow to open and close. But the guy didn't reckon the turbo is wrecked, or at least he didn't say that!
I heard it's advisable to keep the N249 plugged in, to avoid misfires. Which would mean no resistor for that part of the process. Any thoughts?...
whoa getting my combi valve out was like fighting with a gorilla; Bowders didn't mention the bunch of hardlines and other stuff screwed into the back of the combi valve plate. Maybe his was different but it was tough and I expect I've gouged some bits I shouldn't have. Tomorrow I'll put the plate on, and the coolant assembly; then get chopping out the hoses in the N249 area. I made progress today; if the OCC install is this tricky... ...I'll die...
All went to plan (following this guide) until I snapped off the nipple on the DV valve! It's the Bosch one, looked a bit too shiny to be the original but who knows?
Anyway that's VW hose clips for you, the devil's work. The rain didn't help, had to run for cover all the time. Fortunately I have Creation Motorsport about 30 mins away so will throw more cash at this crazy project, and get a new DV (they sell aluminium ones). Which spring should I put in it? It comes with three; my vrs is a stage one map but nothing else upgraded.
Despite this I'm getting better at this ho ho
