Rear wiper motor
I presume its the same in all the mk1 Octavias but is it the same in the Golf and Fabia?. Mine wont stop and the mot is due so need to sort it.
Im sure they are the same for all octys,they may be different in hatch to estate,i replaced mine with a secondhand one,the rear wiper isnt part of the mot test,you could just un plug it for the time been to stop it going all the time.
Edited by mikey vrs
No not the same as in the other skoda versions or octy estate or the VW range. The Octavia hatch has a longer washer wipe section
Just unplug it from the rear wiper motor asm connection. Remove the plastic hatch cover and you can get to the plug. Not a MOT failure
Aslong as its not a fail I will unplug it and sort it later.
Thanks for the help
Thanks for the help
Bsmithmilne........you will see a post elsewhere on this subject......I have had same problem.Try removing fuse overnight, on reconnection motor should have re-set!
Brendan.
Cheers Brendan its worth a shot.
