FL VRS daylight running lights
Hi
I have a face lifted vrs estate and it has the led day running lights.
I noticed when studying the headlights that there appears to be bulb in the housing where the non vrs sidelights are located. Should these light up too when on sidelights? Mine don't.
Also do fl vrs come with cornering fogs as standard or do these need to activated?
Hi
The side light bulbs don't 'work' on a FL vRS, the DRLs just dim when 'sidelights' are selected.
Cornering fogs need to be enabled.
How do you enable the cornering fogs if you have no maxidot on your FL?
The same way as if you do have maxidot... VCDS or hope your local dealer knows what he's doing...
Thanks very much for the information
