E.P.C.LIGHT ON BREAK LIGHT
MY EPC LIGHT CAME ON THE OTHER DAY ,I USED A CODE SCANNER TO CHECK THE FAULT,IT SAID THAT THEIR WAS NO FAULT CODE OR ONE PENDING,BUT THE LIGHT WAS STILL ON ,I CLEARED IT AND IT WENT OFF,I DROVE ABOUT 2 MILES AND IT CAME BACK ON AGAIN,,????,THEN I CHECKED THE BACK BREAK LIGHTS AND FOUND THEM NOT WORKING,,SO THAT IS THE PROBLEM,,I NEED A NEW SWITCH,FOR THE BACK BREAK ,I AM HAPPY AGAIN?
Please stop SHOUTING! ;)
No need too shout ................
You'll probably need a new brake pedal switch and you'll be happy as pig **** :D
A generic code scanner will only show emissions related codes, this is a good example of that.
BRAKES not breaks
