Glowplug Problem
Car sometimes wont start, possibly alternator i thought
was going to replace glow plugs today and look what i found
just a few questions.
1) what has likely caused this?
2) can i just get another glow plug 'rail' of a smashed fabia vrs and connect it with a straight through connector onto my wiring?
3) when i've done this should i put some electric contact grease on the top of the glowplugs to ensure its getting a good connection
4) would this possibly be my starting issue?
thanks
This is fairly typical - and is caused by a crappy VAG detail designed for cheap assembly.
Glowplugs take a lot of current, especially when cold and need a good low resistance connection. PSA know all about this - they use a good old fashioned ring tag and nut, which does not give trouble.
You need a new harness and a new plug. Putting a new harness on the oxidised and sooted pin of the old glowplug will just ensure a repeat performance. I would recommend smearing the glowplug connector pin with silicone grease (nothing else) and repeating this as part of your annual maintenance.
Talk about spoiling the ship....
rotodiesel.
rotodiesel.
hi thanks for that! I have 4 new plugs waiting to go in :) the harness how do you change it? Will i have to cut the old unit out and splice the wiring?? Or does it unplug? Thanks
Have a look at the parts list and see how much harness you have to buy.
rotodiesel.
