Bluetooth Options with Audience MP3 Player
I have a 08 plate L+K with a Audience MP3. It currently has a parrot 3100 fitted which I do not particularly like.
Is Fiscon an option and if it is which one will work and how does i control?
Are there any other "Hidden" options like the fiscon (If I have to install a external display I might as well keep the parrot)
Is the Fiscon and other options voice activated?
Does anyone know of any good installers of the above or where I could buy from and install myself?
TC
Anyone?
TC
I believe the Fiscon Basic Plus only works with the Bolero and the Columbus so probably isn't an option for you. However, if you have maxidot then the Fiscon Basic should work and control would be with either the MFSW or the Stalk controls for maxidot...
Fiscon Basic
Have to say, I wouldn't have thought it would be much of an improvement over the Parrot though because, as far as I'm aware the Fiscon unit is essentially a repackaged Parrot system anyway.
Can you not retrofit a GSM II module in your car? As Ben (shark_90) as a starting point
Edited by Raglits
I have a parrot 3200, which can do voice dialling and IMHO is one of the best options out there. The 3100 is very good and really some of the other options seem to be very poor in comparison.
