clutch problem ?
hi ive got a 57 plate roomster1 and this morning after changing gear the clutch pedal kept sticking down so i tried to limp it home in 2 nd gear but couldnt make it, now it goes into gear when engine of , but wont go into gear when engine is switched on, if you put it into gear when engine is switched off then start it it jumps and stalls , any ideas would be greatfull thank you
get it to a dealer using Skoda recovery - its still under warranty!
