clutch problem?
hi ive got a 57 plate roomster1 and this morning after changing gear the clutch pedal kept sticking down so i tried to limp it home in 2 nd gear but couldnt make it, now it goes into gear when engine of , but wont go into gear when engine is switched on, if you put it into gear when engine is switched off then start it it jumps and stalls , any ideas would be greatfull thank you
  • 4 weeks later...
Any feedback on this problem?
does your clutch pedal stick down to the bottom of the footwell?
mine did this my garage said that one of the cluth rods or something had bent so they re welded it
dont know if this is the same problem as yours
