My vagcom findings
I posted about a week ago about my EML coming on and going off intermittently. I finally got hooked up to vagcom tonight and here are the faults:
Address 01     -------------------------------------------------------
   Controller: 038 906 019 NF
   Component: 1,9l R4 EDC 0000SG  7000
   Coding: 00102
   Shop #: WSC
1 Fault Found:
17664 - Engine Coolant Temp Sensor (G62): Open or Short to Plus
            P1256 - 35-10 - - - Intermittent
Readiness: N/A
Quite easily understood, is it an easy/expensive fix?
And this one which is puzzling:
Address 08     -------------------------------------------------------
   Controller: 6Y0 820 045
   Component: Klimaanlage        X0840
1 Fault Found:
00819 - High Pressure Sensor (G65)
            07-00 - Signal to Low
And the last one:
Address 09     -------------------------------------------------------
   Controller: 6Q1 937 049 D
   Component: 0000 BN-SG.         1S34
   Coding: 25754
   Shop #: WSC 13765
1 Fault Found:
01598 - Drive Battery Voltage
            07-10 - Signal to Low - Intermittent
Can anyone shed some light on the second and third faults please?
Thanks.
Edited by rojer386
2nd fault - usually when you have no gas in AC or presure is too low. sensor is located under G12 tank on the AC pipe. may be loose connection
3rd fault - happens when you disconnect battery or voltage drops below certain level. should be enough just to erase this one... if comes back again check condition of battery and look for any loose terminals in the fuse box on top of battery.
Edited by dj_max
Take your chassis number out of the first post too :thumbup:
Yep wouldn't want a clone of your car out there. It's the TM....... number.
For first one I think either a wiring fault or the temp sender itself. Easy cheapish fix if it's just the sensor, things get more complicated checking for and repairing wiring faults.
