VRS FL Aerial
Hi, just looking at various photos of members new VRS's I notice that they have two types of aerial bases on them, a standard round (ish) type base with mast on top and the other a taller fin type base with the aerial mast on top , as these standard fit and if so why the difference?
Paul
Isn't the one with the shark fin base for the built in sat-nav??? ;)
Dave.
Its for models with sat-nav or bluetooth I believe. Anyone know the part no?
If that's the case, do you need a new aeriel if you upgrade from Bolero to Columbus ?
I used the same aerial & mine is fine. but I have a seperate GPS antenna under the dash
Edited by bandit1
I'm thinking of getting a sharkfin antenna but darent undo the headlining myself
Snap
Got it on mine and its for the bluetooth.
I was thinking about doing the Sharkfin aeriel change, but like has been said above, dont fancy taking the headlining down.
