Just Wondering: Mot & Emissions after remap?
Hi,
Has anyone here (not including switchable maps) had an MOT since being remapped? Reason I ask is simply how does the untrained car enthusiast know whether their recently remapped car will actually pass the MOT/Emissions test?
My car was remapped more than well :thumbup: by Jabba Sports a year ago, and I still have 7-8 before the 1st MOT.
The only reason I've thought about this is that I noticed my car appears to produce a substantial amount of smoke/vapour at rest (even more noticeable now it's cold). Is this normal [Octavia vRS]?
Rich
I had my first MoT test 14 days ago. I have a Jabba map on otherwise fairly standard 4x4. My results at fast idle:
CO: (Pass <= 0.20%): 0.00%
HC: (Pass <= 200 ppm): 3 ppm
Lambda (Pass 0.97 - 1.03): 1.00
So I think you're safe :D
You can even have a full decat and pass the emissions test (just). It's better to leave the climate control on economy though, thereby disabling the air con compressor. The extra load could just make a full decatted car tip over the acceptable level ;)
Xavier's advice is sound. It's also interesting to note that you really can't poison yourself with the carbon monoxide output of your modern car. Suicidal people look elsewhere...
All the above is good to hear :thumbup: , so thanks (mind at rest).
Still, does everyone else (1.8t owners) suffer from excessive vapour?
i have noticed the "excessive" vapour from the exhaust on the vRS compared to my last car but put it down to the turbo (?) dont know if this is correct or not. anyone know ?
My vRS (unmapped) is a bit like a steam engine on very cold mornings, quite a large amount oif vapour. But usually it seems fine, in average weather conditions, comparable to my last car, a Festa VTec :o
CO -0% I find that a bit hard to believe, their sensor must be out. Perfect combustion in the environment of a car engine just aint going to happen.
BTW The CO2 will kill you by excluding oxygen and smoothering you (as apposed to actual poisoning).
