Pollen filter
Can anybody tell me where I can find the pollen filter on a 56 fabia vrs?
If you go into the passenger footwell, and look up at the underside of the glovebox, near the center console you should see a rectangle, being held in place by two clips. The clips will slide away from there current position to the other end of the rectangle, then it should all just drop down/pull out.
Think that's right, but it's done from memory, so maybe slightly out, but it's definatly in that area.
HTH.
Sounds right to me :)
did mine the other day and about a hundred leaves fell out :o
