Voltage stablizer/Ground kit.
Good afternoon,
If you have spare 4/6/8 AWG cable lying about
OR a stubborn older brother who bought a grounding kit and voltage stablizer then realised it wasn't worth ££ EVEN tho his little bro who studies electronic engineering says "thats just very very little performance/efficiency gain for the price (£30)"..............
:rofl: You can then do this with it.. (basically I long term borrowed his stash of car bits when he changed from a fairly heavily modded (N/A) Alfa 159 to a Renault Scenic)
Grounding points were:
~Gear lever thing? (below the battery),
~ Alternator
~ Engine block on LHS.
~ Bolt where it supports the oil can? (Im not sure what this is, its on the bottom LHS next to the belt)
~ Up to the EGR bit
~ Back round to the original body ground point
HTH :giggle:
Edited by JLneonhug
sorry but im lost?
what exactly have you done?
sorry but im lost?
I've connected the -ve terminal of the battery to more ground points around the car using blue cables. 4/6/8 gauge wire would be sufficient, however I would not recommend spending ££ on it. I just had some lying about, improvement on efficiency is very subtle/minimal, it works better with some cars than others e.g. Japanese cars tend to have weaker ground points.
Its not a definate benifit however it would not have negetive effects.
my car struggles to start at times, i think it might be a bad earth, if i were to do this would it help you rekon?
i can get all the cable and crimps from work for free ;)
prob 10 or 16mm would be best ?
If you think its a bad earth then cheapest way is to clean the contacts, the alternative is yes connecting multiple grounds would help :thumbup:
Size wise, the bigger the better. 16mm would be ok though.
