replacing my battery on the vRS
Doing a bit of preventative maintenance and i'd like to replace my batter which is the OEM one. Its 5 years old. It looks different to a normal battery and i've been told its about £100 from skoda? there seems to be additional cables attached to it also.weird looking thing
why is it so expensive? and can i not just swap it for a Varta or Bosch?
Thats not the battery you are looking at as such, if you go under that bit then you will see the standard looking battery :thumbup:
Thanks, So what is that thing? its got cables bolted to it
Its just like a distributor block for the cables to save clagging them all on directly to a terminal.
thanks and any 096 battery should directly replace the skoda one in there?
i've seen a few being sold on tanya, they seem to range from 72Ahs to 77. I'm sure the skoda one is 72Ah. Does it matter? or should i go for the highest Ah I can find?
Bosch or Varta I think are ok. Bearing in mind varta make bosch batteries....lol.
