VCDS fault on new Octy FL vRS
Had a fiddle with VCDS the other day.
Do I need to worry about this ?
What does it mean ?
Thanks.
Thursday,27,May,2010,15:16:46:20782
VCDS Version: Beta 10.3.0
Data version: 20100324
Chassis Type: 1K0
Scan: 01 02 03 08 09 10 15 16 17 19 25 42 44 46 52 56 62 72 77
VIN: xxxxxxxxxxxxxxxxxxxxxxxxxxxxx
62-Door, Rear Left -- Status: Malfunction 0010
Address 62: Door, Rear Left Labels: 1K0-959-703-GEN3.lbl
Part No SW: 5K0 959 703 A HW: 5K0 959 703 A
Component: Tuer-SG 007 2101
Coding: 0000144
Shop #: WSC 73430 790 1012544
1 Fault Found:
00934 - Electric Window Motor; Rear Left (V26)
005 - No or Incorrect Basic Setting / Adaptation
Nothing to worry about at all. Clear code and reset windows, done.
You reset the window, by lowering it all the way down, then raising it and holding it up until it almost makes a noise.
That should then be a reset of it so that error should go.
