leaky headlamp
just noticed when cleaning car today. drivers side headlamp has condensation on inside. was just wondering if anyone has had this issue before. car is an 06 vrs model
also could anone tell me weather the headlamps are a sealed unit or would i be able to take apart and see what is wrong with them?
Have you checked that the cover on the rear of the headlight is on and secured properly? The headlights can come apart im sure there is a how to on here somewhere
If you take the cover off the rear and leave it a day or so it will clear up. Mine does it with the heat from the IC when I've parked up and it's wet. It's the easiest way because to check/split the headlight you have to take the bumper off.
Regards Chris
If you want to take the headlight off and get inside it you could try what I did to spray the inside of the headlight on my old car.
Take the headlight off the car, but it in the oven but not for more that 4mins[/] and then get a knife and run it round the edge that will separate it from the glass, just make sure you get some decent sealant to seal it back up when your done :)
Edited by Lito_VRs
