How Do I Connect Up The Rear Nearside Fog Lamp? (Octavia Hatch And Estate)
  • Administrators
Courtesy of Adrian (SkodiRS) and Denis (DGW)
What you need:
cable/wire suitable for fog lamps (8amp rated) - 4ft is plenty
cable/wire splitter connector - connector to tap off from one wire
junior power timer terminal (female)
  • 4 years later...
This is true of other estates, certainly in the 2002 MY.
Please though, don't do this mod. It will only make your brake lights less prominent in fog. :)
This is currently on my to-do list, along with fixing the bloody leaking rear washer pipe in the rear pillar...
  • 1 year later...
The cable you need to splice into is routed down the left hand side of the car and goes from lhs to rhs along the back of the car (octy saloon ) so you only need to move the carpet on lhs and where the loom splits the wire is visible .
  • 2 months later...
But does it not muck up the can-bus on newer cars?
Radiotwo
