wishbones
can you buy the front wishbones with powerflex bushes already in them on second set already lol :giggle:
Are you saying that the powerflex bushes on your wishbones are knacked?
If so just get a refund and go for the Superpro ones.
I had problems with the powerflex ones and changed them for Superpro ones.
no just on second set of standard wishbones lol just wondered if you could get them already pressed in save me time messing about
No powerflex only come as bushes.
I have a new genuine wishbone for sale if that helps.
have you tryed tt wishbones exactly the same!
ive seen someone else with the tt wishbones on are they alot better than the vrs ones then stiffer bushes ???????????????
tt wishbones are cast. lots of people using the rear bush from a tt though.
Much better than standard VRS bushes, especially if you are upgrading ARB bushes and suspension as the standard VRS bushes takes even more punishment.
I have the TT bushes in my motor, after powerflex ones lasted 4 months. If you have the older version powerflex bushes they are crap and they pull out of the wishbone because they don't have sufficent overlap on the wishbone lip to stay in place.
The TT bushes look the same as the VRS bushes from the outside and how it fits to the wishbone, but the TT inner rubber fills the whole casing, as apposed to the VRS bush having 2 points of contact and thus can move about a lot and eventually tear away from the casing. the TT bushes are cheap compared to the powerflex bushes also.
I can dig out some pics and a install guide if needed.
Edited by Bowders1
that would be usefull!
think
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=400123695287&ssPageName=STRK:MEWAX:IT
is what you after, dont know if the price is any good or cheap at gsf etc.
some pics would be great if you get 5 to post them got to put decat pipe on this week so will do it all one go :thumbup:
will do have a few pics of fitting the decat too in interested.
I don't think the TT cast wishbones are a straight swap on the A4 platform.
The two subframe mounting points are in the right place (hence the bushings fitting the Octy wishbones), but the ball joint mount is different, as the TT uses a different ball joint. You may think that you could just use the TT ball joint then, but they have a different taper where they attach to the hub carrier. So if you want to use TT wishbones, you have to use TT ball joints and hub carriers too, and maybe TT track rods.
I'll be using TT rear bushes in my spare set of wishbones.
Spot on Bodge, they are not a direct replacement and will involve the work you mentioned.
Although when time and funds allow i will be going that route as fitting TT wishbones is less stressful on a lowered car like mine, where the VRS wishbones are sitting negative level.
TT hub carriers are quite different to "normal" A4 platform - TT wheelbase is significantly shorter than the standard platform and hence the steering arms and overall steering geometry will change. It may or may not have significant effect in practice, but bear it in mind and investigate before rushing off to change everything.
Some Leon Cupra also use the cast arms, so maybe their hub carriers may be more compatible?
