Couple of issues would like some advice
Hi to everyone.I`ve got a few questions if someone could shed some light on them.
1. I`ve got an 02 plate octavia vrs and unfortunatly have stains on the fabric on the front seats.Have tried a few fabric or stain removers but no good so far.Does anyone have the solution?
2.Within the last week I have started getting a clicking noise from the cars clutch pedal when pushed to the floor and when released I can sort of feel it as I push the pedal too.Does anyone know what that is all about.
Had the car 4 years and would defo get another.Just had cambelt,water pump done run of the mill issues but worth doing great car.
I appreciate any feed back.
Edited by saxby2026@yahoo
No idea re. the stains, if you have tried all sorts of stain removers then it sounds like you are stuck with them :doh: I've use the Vanish pre-wash spray on stain remover on mine in the past.
Clutch pedal - have you got a clip on the front edge of the drivers mat? When I got mine I kept having this feeling that the clutch pedal was catching on something and it was because I had some cheap rubber mats which weren't held down at the front and they were curling up and catching on the pedal. If that's not it then have a good look at the pedal assembly while you work it with your hand to see if you can pinpoint the clicking.
i got mine valeted profesionally and that brought the seats up mint
Mint flavoured seats... cool :rofl:
Thought you only got them on polo's?? :p
im going to rent a rug doctor as apparently that is more than capable of doing the job, ill let you know on saturday how they look :thumbup:
Clutch - most likely the floor mat, but possibly either the pedal or release fork pivot. Investigate in that order, because I've listed the cheapest things to look at first.
