Vrs cambelt
Anyone know if you need any special tools for vrs cambelt change? Also how difficult is it?
No special tools needed. Torx bits for your undertray.
Spanner (17mm from memory?) to release the aux belt tensioner, once the belt's off unbolt the tensioner (3 bolts) from the alternator and remove that angle bracket too.
Assortment of sockets for:
- unbolting the coolant reservoir mount (just move it to the side, the engine mount connects to the body below it.
- unbolting the lower and middle belt covers, the top just pops off with a screwdriver on the 2 clips
- unbolting engine mounts (easiest with a breaker bar)
Couple of extensions for the sockets.
Tipex to mark the timing on the crank, the cam pulleys are v clearly labelled anyways
Some hex bits for the aux belt pulley
And i think that's about it. The autodata guys do a cambelt cheat sheet for a few quid for this car.
Hope this helps
EDIT: circlip pliers for the belt tensioner
Edited by Mute
cheers mate
my mates a citroen mech and is gonna help i just wanted to check
thanks again
cheers mate
thanks again
Ahhh walk in the park for him then. He'll be used to having to remove everything bar the passenger headrest to change a timing belt coming from citroen :giggle:
Yeah he does get stick for that telling me about taking wheels off to change headlights WTF??????!
