hi were do i find
hi friends i need to up grade for larger fuel injectors for 90bhp/66kw diesel octavia.were do i find them ?
:google: :thumbup:
you could try http://www.jhmbuttco.com/index.html
or someone else might be along with another idea
Joel
Have a check on a few MK4 Golf forums. I believe the T3/4 Transporter injectors fit and offer a considerable increase in fuel delivery on the injector pump diesels.
I'll see if I can find some more info for you. I think you can get them from Eurocarparts.
Had a quick look on the MK4 Forum and they say...
"anyways here are the part no's for new bosch injectors (.216's) as fitted to my car. there are three normal injectors and one with a wire fitted to it. you will need 3x 0 986 430 408... and 1x 0 986 430 556... as i mentioned before you will need a length of the diesel return pipe which you can cut to size and also 4x new injector sealing washers..."
That has been carried out on the 110 bhp TDi and apparently saw gains of around 30bhp. Price is around
hi thanks friends have any one tried out from www.tunit.co.uk there is info on larger intercooler and modified injectors as stage 3. (from x-kits )with a cost of 766 pounds .as i have already fitted a power box will these work?
