ARRGGGH hit a rock
i know this one is gonna have a bad ending :'(
anyway was driving along side some sitework and the lads were nice enough to leave a nice big rock in my path. the rest is obvious
the results...
there was a bubble on the tire wall so i changed it over and didnt notice anything out of place/shapae whilst doing so. Then left to top up the pressure,all seemed normal but on the way home when i hit maybe 45/50mph a wicked vibration started in the steering wheel... tool off the wheel again just to make sure i hadnt done something really stupid but again could not see anything obviously out of kilter. Then when i put it back on i noticed that that side of the car seems to be sitting down a small bit,not even a finger but some. and maybe sitting forward a small bit also, doesnt sound good does it
my thoughts were the shock or maybe the wishbone but i couldnt really see anything wrong apart from the little rubber cover on the shock had slid up some.
any ideas suggestions???
What did you hit it with, the tyre or part of the suspension?
I'd check the wishbone is not damaged, wishbone bushes look ok, ARB is ok, droplink on that side is ok, track rod arm is on properly and not damaged.
make sure none of the weights have fell off inside the wheel this cause it too just a thought
Further to this
If your shocks were already on their way out, you may collapsed them more.
Also check the other wheels and suspension. I've un-seated a rear spring before, which put the car @ an odd angle, about a fingers width.
I hit it with the tyre. definately didnt hit any other part of suspension etc
thats what left the bubble on the tyre wall. i was supposed to replace the rear bushes a while back but hadnt done ethis yet. had a look and cant see any obvious damage.
will try putting other wheel back on and see if its still the same to rule out prob with the spare itself althgough i think this is unlikely
Further to this
ok will have a quick chceck around
thanks
Sounds like a wheel out of balance to me, busted suspension will move around a lot when you brake/accelerate. I Don't see busted suspension vibrating at a set speed.
fair point...im hoping thats what it is anyway. heading out now to put the other wheel back on to see if it is just balancing problem so will know soon enough
thanks for the reply
update
took the spare off,the one that was on when bad vibes in the styeering wheel and put the other wheel back on and as you guys suggested the vibration disappeared so looks like just a balancing problem thank god
wheels in at the moment getting balanced so will know 100% shortly
lucky me...will be installing that rock-breaking-lazer to the front bumper tomorrow me thinks :rofl:
thanks to all for their input :thumbup:
no probs
Awesome! Where did you get that from? Also does it work on dithering idiots?
