Door loom T27a plug pinning on car side
Hi
I am looking to retrofit aftermarket blind spot detection lights in the wing mirrors and researching how to get two wires out to the door. Many moons ago when adding speakers to the doors of my mk3 golf, I drilled a hole through both sides of the plug to create a hole to thread a cable through. I am keen to do things with a bit more finesse.
There seems to be plenty of availability for the door side of the plug e.g. https://www.amazon.co.uk/Wiring-Harness-Replacement-1K0937702C-1K0959843C/dp/B0F7R9DHXW or even indivual wires with the pins on, but I cant seem to find anything for the car side of the plug.
Or is the car side full of wires and I would just need to cut one that is unused currently to tap in to?
Had a look this evening and that’s the wrong plug type.
It’s 8K0972702 which you can also get repair pin out kits for. car side looks to be 8K0 972 701 which I can’t find pins for as yet. Any guidance gratefully received!
Edited by Binx1310
I check my documents for the parts Numbers
According to chat gpt it’s:
000979034 and 000979035
I look forward to finding out if it right!
000979035E
000979034E
Brilliant thanks. If I progress beyond proof of concept stage to install the lights I’ll order some terminals!
You are Welcome
You have a Link from your AliExpress parts?
000 979 034E
https://a.aliexpress.com/_EuSbUUi
000979035E
https://a.aliexpress.com/_Ex7gBue
Then will install the Passat b8 led into the mirror caps as it saves £80 on buying pre-made ones.
LED
https://a.aliexpress.com/_EIdElNC
Mirror caps (Without hole but I have a dremmel!)
https://a.aliexpress.com/_EI3ItCA
Pre-made mirror caps with led.
https://a.aliexpress.com/_Ez8JPmw
And this is the blind spot kit I have to avoid the coding and cabling and cost of OEM.
https://a.aliexpress.com/_EyC34RY
I also have OEM radar brackets and the mounting nuts so don’t have to drill into metal work.
I will install blind spot kit first with its standard lights just tucked into the base of the A pillar and then if it works well I will buy the other parts to make it look OEM and remove the standard lights.
Edited by Binx1310
