Spacer width for rear
Thinking about spacing the rear on the octavia a bit. Has anyone tried 15mm hubcentrics on the rear and they have fitted ok? Just not sure if there will be problems with the depth of the spacer meaning it will hit off the hub before its tight back to the disc, in which case i would have to get 20's?
you should be able to fit 15mm spacers on the rear with standard wheels without hitting the arches or the hub
  • Sponsor
As mentioned 15mm should be fine depending on what wheels your running.
Damian @ DPM Performance
i'm rocking 9" out back with 18mm spacers, et52 though
9"?! You sicko Lee! You running 255mm tyres on them, or some dirty stretch?
That must look pretty fat. How does she drive now? Fair bit of friction you're dragging about there!
215s.... :lol: drves absolutely fine! not crashy or anything! not different to 215s on the 8s
