Holding DSG in 'D' or 'S' mode when stationary
Repeat with selector in D. The engine will rev more sluggishly - suggesting drag from the slightly engaged clutch.
if ithat's on a 6 speed, it could be a "torque converter" type effect perhaps, as the clutch runs in oil.
i wonder if the dry 7 speed is the same?
Edited by redlemon
Mine's a seven speed.
(As clutch comes before the gearbox wouldn't the drag be the same for D & N if the clutch were fully disengaged?)
any drag in the clutch would only be noticeable if it was in D. in N it would just spin the input shaft, i would have thought.
my musing was to do with whether the clutch always drags, as it's in an oil bath. seems not.
What fluid???!!
My DSG gearbox has a wet clutch.
Mannyo is right and I'm wrong. I've devised a simple test which seems to prove that the clutch is slightly engaged even when the footbrake is firmly pressed. Here's the test: place your LEFT foot very firmly on the footbrake; select N; barely blip the throttle with your right foot; the engine will rev freely. Repeat with selector in D. The engine will rev more sluggishly - suggesting drag from the slightly engaged clutch.
Could be that the throttle is mapped differently for D than N, to allow for clutch engagement.
Maybe.
