Rear Shock Nut size
Does anyone know the size of the nut that holds the rear shock to the top mount?
i need to know by tonight as i need to change the rear shock and need to purchase a swan kneck spanner :)
thanks for any help
thanks for any help
16mm.
Where did you find that as haymes was useless? :thumbup:
Cheers for that! :thumbup:
16mm.
A 17mm will fit & undo them, You may struggle to find someone on the street (As such) that stocks a 16mm Swan neck / Offset spanner
Dean
Halfrauds do a 15/16mm ......... 15 one end 16 the other..........
So is the real size 16mm?
I can't definatively say from memory but if you get both then you are covered, Plus you will always use a 17 in the future as it is a more main stream size ..
Dean
Aww what! more bloody spanners to loose in the garage! :giggle:
or dumped in your messy tool box along with half the tools from our tool box:giggle:
Edited by lfc958swmbo
its 16, but try and get that that top mount off! :wall:
I agree 16mm - I've got an open ended ?mm X 16mm and an offset ring ??mm X 16mm, but I have not got a 16mm combination spanner - that is being sorted out soon as VAG do tend to like "16mm" - as I've discovered only too often!!
Just had word from my friendly garage man.......
To get the top mount off the shock took 200PSI.............. :no:
You can't beat air impact tools for stubborn Bits :D
Dean
i know what im investing in next :giggle:
