Weird electrical problem, resets diplay
Hello,
the last two days I have experienced that when I stop the car, the cabinlight does not come on, and if I turn the key not ligts comes up on the display.
But I can start the car.
Then the ligths come on the display, but the clock is reset til 00:00.
The radio behaves like is has been disconnected, comes up with the "SAFE" message.
Like the battery has been disconnected.
It does not happen every time.
Any ideas ?
regards
Thomas
dodgy earth connection?
I would start off by checking battery connections are tight and all fuses in the box on the side of the dash are fully home. I don't know if the fuses on top of battery are related to the circuits you mention, but I have seen posts on here before where they can cause problems.
Thank you for answers.
I will check the fuses tomorrow, the connections to battery are ok.
I am considering the battery itself.
The car is about 3,5 years old, so maybee it is time for a new battery....
Regards
Thomas
Hello again,
there were no problems with the fuses.
But the central locking system is also acting weird.
It will not always close at the first time, but I can get locked by pushing a couple of times.
Like it does not have the power to lock it the first time.
I am still thinking about the battery, I have never had these problems and I have driven the car for 30000km, it has now turned 90000km.
I am driven 100km each day.
But the last 14 days I have been on vacation, and have rarely used the car, so I am thinking the battery have not been charged well enough, and when it is almost 4 years old....
I will see if I can get the battery checked before spending money on a new one.
Regards
Thomas
I had the battery checked, and it showed no error, however, the VAG COM showed some errors related to the battery.
So I changed the battery and no errors since then.
Regards
Thomas
