Headlight Failure
My Fabia VRS has just developed a problem with the driver's side headlight. The bulb is fine - does anyone know what the problem could be?
when you say failure, one assumes it's not coming on at all. Main beam or just dipped? one or both?
Next stop has to be the fuses.
Check out the FUSE PANEL LAYOUT HERE
Edit: just read it's the drivers side :doh:
Edited by Jonny5ive
Just driver's side main beam - really stange...
How do you know the bulb is okay , have you swapped it into the other side or tried it in another car? Id still think the bulb would be the cause..... if not then it has to be wiring , dodgy connection somewhere perhaps?
Fuse number 23 or 30 then :thumbup:
