Guide: Fitting Seat Sport FMIC
Not to resurrect an old thread but... i need to resurrect it to ask a question!  :notme:
the part where you start trimming the black plastic cowling to fit the FMIC BEHIND it, is this the way it's always done? as far as i was aware the FMIC was mounted in-front of it?
can someone correct me if i'm wrong? the way i read it is that you did this through choice to make it look a little more stealth, am i correct? so this step could be missed out if not fussed about the stealth look but it would infact mean you'd probably have to do more chopping of the crash bar or put on a crash bar from an ibiza?
cheers, Fraser!
The 'cooler brackets attaches behind the radiator surround, so it must be cut to allow fitment.
Although I installed an Airtec kit, this is the same as the SS 'cooler. I offered the bracket up, along with the 'cooler and worked out what needed chopping out....
baccdd49-154a-4bb5-ada2-09076f9051bb_zps
e61b7b5d-3648-4bdf-b706-597cf0b3a80d_zps
Before .....
E6AA4D99-9198-47B2-8E39-F9EC31B2559C_zps
... after ....
B08E5901-03DC-45BB-9713-AFF0575A406F_zps
13B90D1D-D346-45DD-96EE-9F0ADE08FCBE_zps
I had to mod my crash-bar a fair bit so to make sure that none of the pipes was resting on it. The concern was the eventually the rubber pipe connectors would eventually get a hole in them, causing a boost leak...
Cut the lip off the to and bottom, ground down and painted with Hamerite
0B6FC4C7-241E-4AFB-900D-3790AA56EC64_zps
037AAB8A-2FDA-40E6-AA41-6A7B97DCF832_zps
...... and cut out a section more towards the middle of the 'bar to allow enough room for the top pipe out of the 'cooler
7E88A4E2-2084-4A80-9D13-BFEF1A109F48_zps
  • 3 years later...
  • Replies 53
  • Views 48.3k
  • XLBaconDoubleCheese
    XLBaconDoubleCheese
    Excellent guide, and much needed. I dont know why anyone would pay more for the forge intercooler tbh, i noticed the past few weeks more people taking a interest in these. I`m a bit comfused about the
  • Good little guide but I dont think that MAP sensor wiring will last long like that, you really need to extend the loom.
  • I was told by unit 18 that the Forge one still needs a bit of cutting.(To what I'm not sure) Also the forge one is pretty small in comparison.
Can't see the pictures for some reason . Would you be able to send it to me please . I am planning to fit mine next weekend. thanks would be much appreciated
When I’ve got time I’ll see if I can find and upload those pictures to Flickr and repost.
Does anyone have a PDF of the original fitting guide please?
