Fabia brake fluid = 2 litres right?
For a full flush through and replacement? Going to be buying some performance brake fluid but don't want too much as it doesn't keep for ages.
Tried a search too but too many hits, none specific enough.
2 litres should be plenty, it usually takes about a litre.
i just put standard 5.1 in
i got 2l
I always overdo it and buy the 5 litre cans of brake fluid from Halfords lol, I think the official figure is something like 1l, but if you're being more thorough then 2l is good.
Will, probably buy 1.5L as at £10+ for 500ml, its not cheap fluid :D
What are you buying for it to cost that much ?
DOT 5.1 fluid is only £3.10 per 500ml at my local motor factors
I hope you are not using DOT5 silicone fluid - that doesn't mix with normal brake fluid and i'm not sure that it's compatible with the seals in VAG brake systems.
Nope - actually using a Dot4 but it is the dogs danglies stuff that easily outperforms 5.1 - Motul RBF600. Just ordered 1.5 litres for £37 all in from Opie Oils. Basically it should mean my brakes never fade on track, or at least last a lot longer. :thumbup:
i've heard soem good reports about Motul RBF600 from some motorcycle riders, i'd be interested to hear what it's like :thumbup:
