15 inch steel wheels
Which cars use 15 inch steel wheels which will bolt on to my felicia? I know Corrado wheels fit, (and would be lovely) but I dont fancy my chances of finding a set. Does anything from dead common cars fit; focus, vauxhalls, rovers japanese etc???
Won't be focus - wrong PCD. Vauxhall are a possibility (4x100), but I'm not sure about the spigot size on them.
Felicia spigot size 57.1
Vauxhall spigot size 56.6
the steel winter weather wheels from a mk2 golf g60/corrado g60 are 15" and they fit perfectly, they cost about £37 each from the vw dealer... a member on here called pinkskud had them on his felicia a while back, if you do a search you might find some pictures
As stated, G60 steels are the perfect size and can still be bought new from a VW dealer. have a look on edition38 and CGTI for some second had sets as people buy them from winter wheels.
Dave
Thanks for your help, I have found this website which seems pretty handy
http://www.alloywheelsinternational.com/wheelfitmentguide.html
It seems bmw mini wheels fit too, correct offset, the bog standard model has steelys.
I shall search for some vw ones too methinks
The BMW Mini has a smaller spigot to the Felicia
Yep - by about 0.1mm... so very close but not quite!
Cant that be reamed out though? 0.1 of a mm is gnats do-da! Half round file or sanding drum in a drill??
for the same of 0.1mm i would just whack it on there... 0.1mm wont make a lot of difference :thumbup:
