VAG COM 908 Cable (hex)
Just a quick one can these cables and provided software of ebay read/clear codes and turn afew options on/off like locking after 10mph,i know theres no support on this from ross tech but dont want to invest 300quid+ and only use afew times also do they they crash when auto scan is activated as usb connection.
Edited by gaz130
Some are hit and miss, if you have a CAN based car you will also need the pukka thing as the ebay jobbies won't work.
Cars a octavia mk1 tdi pd 130 on a 04 plate just dont wana spend full amount on full version and dont use it that often.
You could always asked someone in your area, off here. to use there VCDS
I got mine from HERE
£249.95 with next day delivery., top customer services and an authorized dealer
Has anyone tried the Ebay cables and got them to work?
I bought one due to it being cheap and I wanted to scan the car (one of these type... http://cgi.ebay.co.uk/VAG-USB-DIAGNOSTIC-CABLE-409-1-OBD2-II-LEAD-VAG-COM-/330399696070?pt=UK_Diagnostic_Tools_Equipment&hash=item4ced5b44c6)
It performs it's initial test correctly, but then fails to do anything else, including reading the DCTs. A full kit from Ross is simply out of my price range so had hoped
using this and the VCDS-Lite (which is free for home use and supports 3rd party interfaces) would work. The Skoda Fabia VRS '06 is a standard K-line/HEX
interface and not a CANBUS I believe, so might be the cheap interface (from China I guess).
Cheers.
Have a look at the feature list for VCDS Lite on the ross tech site.
This works with the generic cables, so if this can do it then it will do it if the cable works.
If the cable claims is will do everything, then it's an illegal clone and if it fails to work correctly you stand a good chance of messing your car up.
