Anyone got a roofbox on their Octy II?
Just wondering if you could post some pics and give details. I have been looking into them, but have found the Octavia has a very short length in terms of roof length. This inhibits me a little as the plan is to put a child's buggy up there.
I had a Thule Atlantis on my Golf V and there was loads of room for my kids' pushchair & lots of other stuff besides.
I'm certain you'll have no probs doing the same with your Octy!
our one is the size of the roof it is a mont blank 450 vista great box :thumbup:
Thanks, can you remember the model number as there are several Atlantis models.
Is your Octy the hatchback version? Did the box overhang at the front and rear?
Info on that:
Mont Blanc Vista Roof Box - 450 Litre
VS450
Mont Blanc roof boxes are suitable for use on a wide range of vehicles. They are designed to look good and be easy to use.
Capacity: 450 Litre
Material: ABS
Size (L x W x H): 175 x 95 x 38cm
Load Capacity: 50kg
Locks: 3 Point
Think it was called the Atlantis 200, but it had 450 litre capacity. Great piece of kit. Really well made and durable. All from
memory, as sold it shortly after I chopped in the Golf for the Octy - have all the space I need now!
Good luck.
Good luck.
:thumbup:
i have a mont blonc rbx 3100 on mine.
when it was on it was just off centre on the length it pushed the areal down a wee bit and was a bit over the front o the roof but it was ok no prob could not do without it on holl . :p :p P.S. my car is a hatch hope this helps you mate :thumbup::thumbup:
Edited by peachy26
I've still got the Atlantis 200 I bought for my Outback. The Skoda def has a shorter roof length and I need to remove the aerial to get a decent front overhang/still opening the rear door compromise. If buying now, I'd prob look at the 600 - 100l less volume, so shorter.
Kent
Kent
I thought the 600 was longer 190cm as opposed to 175cm (200),
Thule Atlantis 800 = very good.
Now also have some Thule proride bike carriers for the roof too..
Hi
Look at Atera roof boxes on www.roofbox.co.uk - a much cheaper option than the likes of Thule etc but with excellent build quality - I've used one of these on my Octavias without any problems. Set up is quick and easy.
Regards
Chubbs
