HEADLAMP REMOVAL
HI THERE
how do i remove the headlamp on a 07 mk2 octy
You will find a white plastic wing nut behind the headlight cluster.
Unscrew this and remove to a safe place
at the front base of the cluster there is a body coloured hook .
Pull this..Its quite hard first time...I used a cloth around it.
Its then a simple matter of gently coaxing the headlight unit forward.
To remove it completely you will need to remove the wiring plug (Easy)
To replace make sure you line up the unit exactly or it will get stuck.
It just slides back in.
Edited by ChrisRs
many thanks ChrisRs brought a disc off ebay or octy mk2 but wont load because my pc is a 64 bit
any idea what nuber the sidelight bulb is .cant see it in the handbook
Edited by vwdan1986
I am sure how to remove the headlight is in the manual, as its recommended to renew bulbs?
for bulbs see powerbulbs
Edited by lozparry
:thumbup:
thanks. yes forgot about power bulbs nice one :thumbup:
Be aware the sidelight bulbs are a right b****r to get out of the headlight!
Alan
  • 3 years later...
i've just changed the bulbs on my 07 vrs, i noticed the plastic covers on the back of the headlights has a hole the size of a two pence in them that has been tapped over any ideas why
Alan
Mine are in for Life, not to be touched    :no:
Probably someone before you fitted after-market HIDs and made holes for the cables to the ballasts
+1, that would be my guess.
Sidelights are 501 bulbs if memory serves.. I changed mine for some LED canbus jobs, work well really!! 5 quid off ebay... and if you find the white wingnut and black thread are knackered then you will be pleased to hear you can get these replaced for about 4 quid at a dealer!!!
Alan
A nice thin long nose pliers does the job.
