Octavia Scout 1.8TSI 2009 Clutch & Flywheel
Hello,
Looking for pictures and schemes of Clutch and Flywheel for Skoda Octavia Scout 1.8TSI 2009, engine code CDAA. Have one set, but I'm not sure it is correct.
Well, it seems that I found what I needed. Here is the information for the rest of the TSI owners.
1.8TSI (CDAA) and 2.0TSI after year 2009 are using the same flywheel with 240mm diameter and 8 bolts to the crankshaft (not 6 as the old TFSI models). This means that every owner of such engine could replace its dual mass heavy flywheel with performance clutch kit compatible with 2.0TSI year 2009 with 8 bolts pattern on the crank.
good luck
Edited by qu@ttro
